0 members (), 110 guests, and 7 robots.
Topics128,186
Posts1,057,319
Members48,469
#912290 01/16/2013 7:26 PM
Could anyone tell me the weight on the rear wheels of a '57 Suburban? I am changing the rear suspension and need this info to pick the correct new coil springs.
Thanks!
'57 Chevy Suburban; '70 Chevy Impala.
Sir Searchalot
Sir Searchalot
1789.862549 Lbs if weighed in the northern hemisphere and no hub caps.
3106 Rear Doors
front: 1930 lbs
rear: 1945 lbs
1050 lbs payload (96% on the rear)
3116 End Gate
front: 1940 lbs
rear: 1950 lbs
1025 lb payload (96% on the rear)
Thanks, I will take tclederman numbers!
Sir Searchalot
Sir Searchalot
I guess he's close enough for spring selection.
