| | | Forums66 Topics128,142 Posts1,056,472 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | I know the serial number will tell all and I should have that information tomorrow. I have very little experience (none) with the GM straight six but I think this looks like a high water pump. Can you spot anything amiss from this dark and crappy photo? [img][IMG] http://i1035.photobucket.com/albums/a437/mendonjo/c3f8edef36687dc72fe40bfafed24e68.jpg[/IMG][/img]
1955 First Series 3100
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It looks correct to me! Has the correct valve cover. Looks like the side mount bosses are not drilled and threaded, so it looks like it is from a truck. The number behind the distributor will confirm.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Looks like a '55 to me although mated to an earler style starter.
Drew
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Drew, that would be the correct foot starter for a '55 truck.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | How would you tell a 54 from a 55-1st truck engine without knowing the engine code? One of the things "amiss" is the color.  | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | looks like a pre- 55 2nd to me
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | After doing extensive research, it has been determined that a shade of orange/red was used on engines in the Baltimore truck assembly plant (in honor of the first year of the Orioles). | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | How would you tell a 54 from a 55-1st truck engine without knowing the engine code? One of the things "amiss" is the color.  There is no difference between a 54 and a 55 1st series except the code next to the distributor. After doing extensive research, it has been determined that a shade of orange/red was used on engines in the Baltimore truck assembly plant (in honor of the first year of the Orioles). ??? The engine has obviously been repainted.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Post the casting numbers so we can help.If it's all original from factory,I'll say 1954 235 .
The 1954 valve cover had the slot cutouts in the top of the cover.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thank you, Dave
Tim, that valve cover has the 54/55-1st slots/slits in it. I have that style valve cover on my 1960 261, to make me feel better about putting that engine in my 1954 Suburban.
As you know and posted, if someone wants a definitive identification, casting codes and the engine ID/serial number is the best way to identify an engine's block and head.
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | The engine number I got from the seller is
0151598F550
I cant figure out what the last digit means
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Might it be F55Q ?
That would be a 1955-1st 5000 series with a HD (261) engine
If you gave the head and block casting codes, they will help with the ID
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | I have asked the seller if the last digit is really a 0. I will call him this evening to get some casting numbers. I am guessing if it really is a 261 it's not something i would want to put in my truck.
Thanks Guys,
Joe
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | if it really is a 261 it's not something i would want to put in my truck.
Joe Why not? | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Okay, let's try it again. This time with the last letter being a U
Joe
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That would make it a 1955 1st series, 235 Thriftmaster with heavy duty clutch, 3100 (1/2 ton) truck.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Sweet, that's what I want. Incidentally I just got a few more casting numbers
3835913 head B34912 head K104 block above the starter 3885911 block near the fuel pump
It seems the go to place for identifying an engine is the Old Car Manual project page but it doesn't list Q or U and the 54 I used to have ( I still miss that truck) ended in X and that's not listed their either. What am I missing?
Thank you very much to everyone that helped my through this purchase. I now have the engine and transmission I needed.
Joe
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | I can answer my own question now on the serial numbers, when you go the old car manual page there is a summary page that lists the engine serial numbers by year. Don't use that summary, go to the specific manual for your year and look up serial numbers. There will be a section on serial numbers that will include engines, transmissions and rear ends.
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | I was thinking that Tom, the owner was using a flashlight in a dimly lit shed to read the numbers. Unfortunately I cannot get the engine until Easter time. I am working in Germany and won't be back in the States until then. Even then it's a six hour drive to get the motor and transmission.
So far my Chevrolet is really seeing the USA....truck from Arizona, box from California, and the engine from Virginia. Now I just need a few parts from Florida ( the driver is from Michigan) :-)
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | my book says block is a 1953-1955 PG head 1954-57 235 small temp sender
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Tim, what book are you looking in?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That would make it a 1955 1st series, 235 Thriftmaster with heavy duty clutch, 3100 (1/2 ton) truck. F55Q and F55U are 1st series 1955 truck engine codes (this is a large download). The two 1955 trucks specifications manuals are not on the Old Chevrolet Manuals website - they are available at the GM Heritage Center. Tim, Did you ID the engine based on casting codes or engine serial number? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Tim,I didn't look at the engine serial number.
I looked at the casting numbers and referred to my inline 6 engines book.
MSA-1 Chevy Inline 6 Engines 1929-1989 Factory Casting Number & Code Guide
Oltrucks on this site use to sell them,he still may.
Does the block have the captain bars on it ?
Tim
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Tim, one needs to be careful with most casting number compilation charts, most have many errors. I prefer GM charts like the one the other Tim linked to above.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tim, If that is the small booklet that has GMC and Chevrolet codes in it, that little booket has more than a few conflicting/erroneous entries in it. Do any of the Master Parts Books have head and block casting codes in them? I have made a table of block/head casting casting codes gathered from various web sites, but there are conflicting and questionable entries. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I am interested in block and head casting codes. I think those codes are all engine serial numbers.
