3 members (Pre '68 Dave, 52Carl, Bill Marlow), 50 guests, and 2 robots.
Topics128,090
Posts1,056,028
Members48,432
#911884 01/15/2013 9:15 AM
Leo
Offline
Moderator
Moderator
http://s365.beta.photobucket.com/user/1953panel/media/DSCN02132_zps6c4f430d.jpg.html
http://i365.photobucket.com/albums/oo91/1953panel/DSCN02171_zps45ddb49d.jpg
After checking the entire system to determine why my fuel gauge is not working, I took out the gauge. It's a 53, 6v gauge with the 12v reducer on the F side of the gauge. (My battery is now 12v.) It looks like something is fried, looking at the back of the gauge. I guess I need another gauge?
Leo #911912 01/15/2013 10:56 AM
On my 1954 (different gauge) the reducer goes on the "input" side of the gauge, the post behind "Empty").
If it is installed reversed, the gauge gets fried. Originally, there was a red warning tag on the Full/Sender post on the back of the gauge.
Here is a photo of the runtz-style reducer on a pre-54 fuel gauge. You can see the remainder of the red warning tag on the sender side/post.
Leo
Offline
Moderator
Moderator
Tim, thanks for that pic. My gauge still has most of that red tag, same as what you show. I see that you have the small black wire with the resistor fastened to ground. Mine was on the terminal beside the tagged terminal. I guess that caused the short, causing me to drive around all year on E.
Leo
Offline
Moderator
Moderator
Next question: The gauge is supposed to be isolated from the housing, right? It has two little papery insulators on tabs on the edges of the gauge. (I wish my pics turned out larger, will try to change them)
Yes.
the two tabs on the ears help insulate as well as the insulating paper on the back, as in tcledermans pic.
the metal plate on the back of your gauge is the ground for the gauge. So it need to contact clean metal in the housing.
That illustration does not show the reducer fastened to the ground. It is in-line with the power cable on the power-in side of the gauge.
You fried your gauge by attaching the power/reducer on the sender side of the gauge. The ground is provided at the gas tank sender.
Leo
Offline
Moderator
Moderator
That illustration does not show the resistor fastened to the ground. It is in-line with the power cable on the power-in side of the gauge.
It looks like it is attached to the gauge housing bracket. So it's on the other terminal?
in the pic, the resister is attached to the power post of the fuel gauge. The E terminal
there is a small black wire with a red terminal coming off the resister and is attached to a gauge mounting post in the dash.
that is the ground for the resister.
Leo
Offline
Moderator
Moderator
I got it now. Thanks to both of you.
I apologize or my confusing post. I had never used a grounded Runtz-style reducer.
This style does not get grounded. Maybe the difference is that the one with the ground wire can be used in either a positive or negative ground application?
