1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91158 06/15/2002 11:19 AM | Joined: Sep 2001 Posts: 23 Member | | Member Joined: Sep 2001 Posts: 23 | I installed daul 11" electric fans in my "59" Apache, I ran it for the first time yesterday and the fans worked great for about 15 minutes then they stopped and i noticed the relay for the fans was super hot, the wiring is all correct, the relay and fans are brand new, Wadda Ya think?
1972 Chevy Cheyyenne, 1959 Chevy Apache
#91159 06/15/2002 5:02 PM | Joined: Apr 2002 Posts: 36 Member | | Member Joined: Apr 2002 Posts: 36 | Pappa J, two things come to mind --- 1) too much current for the relay, or 2) bad relay. I lean toward the former as starting point. If the relay was originally intended for only one fan then you may have "over-amped" it. What is the current rating on the relay? What is the sum of the current draws for both fans? Did it work again after it cooled down? jt | | |
#91160 06/16/2002 4:10 PM | Joined: Sep 2001 Posts: 23 Member | | Member Joined: Sep 2001 Posts: 23 | The fans draw 25 Amps total and the relay is rated at 30 amps, I just double checked the wiring again and it is correct. And the fans do come back on once the relay cools down. The relay turns on the fan at 180F and shuts it off at 160F What i dont understand is the directions say to use a 180F thermostat, But if the fan turns on at 180 and the thermostat is just starting to open i will never get any water thru the radiator and thus the fans will never shut off, and they do run costintly until the relay overheats and shuts off........
#91161 06/17/2002 12:14 AM | Joined: Apr 2002 Posts: 36 Member | | Member Joined: Apr 2002 Posts: 36 | Does the relay have 3 wires for the contacts? If I understand you correctly it is also a temperature sensor. Besides the common lead, if there are connections for both normally-open and normally-closed contacts then you may have it wired to the wrong contact where the fan is turning off at 180 instead of on. Just a thought. I think I'd be talking to the manufacturer next. Keep me posted.
I'll be back in a couple of days. My daughter is taking me sailing for Father's Day. jerry | | |
#91162 06/20/2002 11:11 AM | Joined: Sep 2001 Posts: 23 Member | | Member Joined: Sep 2001 Posts: 23 | Well I contacted the manufacturer (ron francis) He says i need to hook another relay up for the other fan, says one relay is handling to many amps. Thanks for your help jerry, Bon Voage!
#91163 06/20/2002 4:08 PM | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | | | |
#91164 06/22/2002 11:32 AM | Joined: Sep 2001 Posts: 23 Member | | Member Joined: Sep 2001 Posts: 23 | Thanks randy, I think i got it right, We will soon see..............
