1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Roy,
Like I said, it won't go through all the detents with the engine not running OR with it running. Somehow I have to run it for a while........stop.........then it will let me shift it down in LOW. You're right, the linkage is out of adjustment.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Disconnect the linkage at the transmission to make sure the shift shaft that comes out the side of the transmission will go through all the detents. Make sure the wheels are blocked so the truck can't roll. You should be able to manually rotate the shift and see if it will allow you to go through all the gears. The engine does NOT need to be running for this test.
If you can shift through all the detents with the linkage off, then you should be fine inside the transmission. If you can't, then you have a problem inside the transmission with the way the linkage is hooked up there.
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Thanks Roy. I'll do some diagnostics on the tranny this week. Good idea about taking the linkage off and seeing if it will go through all the detents. Thanks for the idea.
