0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91073 07/27/2004 1:35 PM | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | My truck is a 49 1/2 ton. Is the Accessory terminal on the ignition switch "hot" when the ignition is on or just the Ignition terminal. In other words, which one should I attach things like heater, wipers, radio, etc. | | |
#91074 07/27/2004 6:19 PM | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | The accessory terminal will be hot in both the Ign. and Acc. positions. Run the power to the coil from the Ign. position, and power everything else from the Acc. terminal. If the switch has a spring-loaded "start" position, it will switch off accessories during cranking, to provide max power to the ignition system while the starter is running. Jerry
