5 members (Uncles51, 55shaker, Woodcmiami, Stovebolt48, joe apple), 65 guests, and 3 robots.
Topics128,021
Posts1,055,351
Members48,420
#909858 01/08/2013 6:59 PM
Can generator or regulator cause damage to switch? (History) A few days ago I was running truck and and testing lights. I noticed a headlight burning low. Shut er down as it was to cold that evening. On weekend took er for a run about 5 miles. Today I have no lights,pk lights or brake lights. Put new switch in when I changed wire harness 6 months ago. Got any suggestions
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
a faulty switch isn't likely to be caused by generator problems, but the new repro switches aren't always the best quality - I'd pull it out and check the functions with an ohm meter, particularly the thermal contacts on the switch, and make sure the main power connection isn't loose
Thanks red58, I will give it a try (ohm) I checked connections there fine.
More pix on Flickr
Short out the thermal contacts in the switch and see what happens. I had a new one go flaky on me also. Seems like the reproductions can sometimes be suspect.
don
DUH HUH, checked for power to switch at bat term no power. Checked wire diag found that bat term on switch wire runs to c term at ammeter gage and that was unconnected. Hooked up all wires properly and everything is working again. Loose ground caused one headlight to operate dim after tightening its bright again. Thanks for your help
More pix on Flickr
