| | | Forums66 Topics128,185 Posts1,057,284 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90956 06/21/2004 5:20 PM | Joined: Jun 2004 Posts: 25 Junior Member | | Junior Member Joined: Jun 2004 Posts: 25 | I just recently bought a 3/4 ton thriftmaster (1948). It has been converted to 12v in the past. However, it never had turn signals added. I want to add turn signals to it using the front parking lamps and rear brake lights. I was going to get the 7-wire bolt on turn signal assesory for one of the various parts suppliers, but wanted to see what other parts I may need. Do I need to convert the bulbs and/or sockets? How do I tell? Do these add-on switches also have 4-way flashers? thanks for any help or direction on this one. Aaron
I can't drive 55... no really, I can't!
#90957 06/23/2004 1:56 PM | Joined: Feb 2004 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 41 | hi tank i just the signal light and dual tail lights on my 56 stepside.i do beleive the 3 prong flasher is what gives you signal lights and 4way. iwill know tonight as i just have to hook up flasher and try everything. you will need a flasher and plug, as the clamp on switch does not come with these items.you will have to do the dual element socket for the lights as well.hope this helps some  | | |
