0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 166 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 166 | Is thickness of wood critical in replacement boards for the bed ? I am building back a 3 ton 51 gmc and the bed needs all new wood. I could go with the standard pine 2x8's or I have some 1" thick cherry. I dont plan on really hauling tons of weight on it, my other truck can do those jobs. Any thoughts ? I appreciate it  Troy | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | for a DIY flat deck the boards can be what ever you have, 1" would work, cross sills can be added to strengthen it for thinner boards
Bill | | | | | Joined: Jun 2012 Posts: 166 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 166 | Thanks alot for the suggestions here.... That is good to know, that I can use whatever will work  Also, CASO, that is a great chart there. Thanks for sharing. Troy | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I don't think the thickness of the wood is critical , but I do think it would be sensible to carefully consider the use you plan to put it to , then add some for the unplanned events  The decking on my pickup is 28mm , because that is what I was able to achieve. It is a Malaysian hardwood , because that is what was available. Oiled up it looks fabulous and is durable enough to see the trucks life out too , I think.  | | | | | Joined: Jun 2012 Posts: 166 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 166 | Thanks Dusty, I agree with your thoughts totally.... I bet the wood in your truck bed looks awesome  | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | What's the front to back spacing for the supports under the bed? On my 46 there are 4 supports one on each end and two in the middle. If your's is a flat bed and greater spans the thicker material will be better. Try a few pieces on a pair of saw horses placed at the support distance you have and see how it flexes. Fyi Pine is soft wood cheery is harder but not real hard. | | | | | Joined: Jun 2012 Posts: 166 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 166 | There are 10 supports/cross members including the front and back. It has plenty of support back there... Too, I dont plan on hauling too much weight back there as I have another truck for that  Thanks for advice. Troy | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | On some flatbed models the bedwood needs to "tuck" inside the side steel frame or front steel frame work, which would require you to mill the difference in height. | | |
