9 members (cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible),
109
Mod | | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90746 01/15/2002 12:07 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Hey, fifthave, I tore my heater assembly out over the weekend. I'm getting the core pressured checked and cleaned up, and I'm gonna sand and repaint the housing.
Got a question about the blower motor. I've converted to 12 volts. Will the six volt motor work OK in that setup? Do I need to add a Runtz voltage reducer? Or should I just spring for a 12 volt motor? | | |
#90747 01/15/2002 1:54 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You'll have to add a resistor if you use six volt motor. If you convert to 12 volt make sure motor you buy runs in same direction as motor you replace. Should have approxiamatly same rpm.  | | |
#90748 01/15/2002 2:07 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Thanks Whitelightening. Is there any advantage to the 12 volt over the 6 volt? Also, I think this 6 volt motor has been run a few times with the 12 volt battery. If I hook the motor to the battery to test it, will it smoke it? Or will it run for a while before it craps out? | | |
#90749 01/15/2002 3:26 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can run that motor on 12 volts, but you will get tired of listening to the noise. For about $25, you can put in a Dayton motor from Grainger, should outlast any other motor. Here's a thread 12 volt heater motor
Fred 52 3600 69 C-10
#90750 01/15/2002 4:16 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You could test it on 12 volt, but you don't want to leave it hooked up more than maybe 30 sec. tops. It will run faster on 12 volt, but will burn out in short time. The only advantage changing your motor to 12 volt (as opposed to adding resistor to six volt motor) would be less current draw.  | | |
#90751 01/15/2002 3:02 PM | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 |
Jim
#90752 01/16/2002 3:26 PM | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | | | |
#90753 01/16/2002 11:09 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Randy, I think you're on to something here. All of the hours that I drive my truck during the day, the lights are off. So, I'm saving electricity and thus saving money, right?
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
#90754 01/17/2002 2:46 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Randy, I'm writing that one down so I can remember it when I need to use it.  | | |
#90755 01/27/2002 11:29 PM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Jimfred, I bought this motor and mounted it in the heater housing, and then I discovered that the shaft was narrower, so my squirrel cage doesn't fit on the shaft. Any suggestions where I could get a squirrel cage that fits? | | |
#90756 01/28/2002 1:07 AM | | Anonymous Unregistered | | Anonymous Unregistered | You would be better off making a bushing than trying to find a new fan. What is the O.D. of the motor shaft? I could make you one if its a hassle to have done local. Ray | | |
#90757 01/28/2002 1:59 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Originally posted by Metal Man: You would be better off making a bushing than trying to find a new fan. What is the O.D. of the motor shaft? I could make you one if its a hassle to have done local. Ray It looks like the O.D. of the motor shaft is 3/16, and the I.D of the squirrel cage is 5/16. The problem is, the set screw won't even go in far enough to seat against the motor shaft, so the bushing would almost have to be a press fit on the motor shaft so the set screw could seat on the bushing. I'm going to see if I can find a squirrel cage that will fit the shaft, because I think that's a better solution. Even if you bushed it, unless it was truly a press fit, there's a chance it might come off or at least rotate on the shaft. Only way I can see around that is you use a set screw on the bushing to hold it to the shaft, and then the set screw in the cage to hold it against the bushing. | | |
#90758 01/28/2002 3:43 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can also drill a hole in the bushing so a longer set screw will engage the slot on the shaft.
#90759 01/28/2002 5:06 AM | Joined: Nov 2001 Posts: 72 Member | | Member Joined: Nov 2001 Posts: 72 | I replaced the blower motor in my 60 with one out of a something Dodge. The shaft wouldn't fit the cage, so I went to my local hardware store and they had cages with different shaft and OD's. I found one that fit great. It also works great. Dennis | | |
#90760 01/28/2002 5:07 AM | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | I finished restoring the heater from my '53 1/2 ton (recirculating type) today. I used the Grainger motor as ya'll suggested and it fit perfectly. My heater came with a fan blade instead of a squirrel cage, so the shaft dia was exact. Now, the on/off 2 speed heater switch that came with my truck started to smoke whilst I was testing it using a battery charger for power. Everthing worked, just got hot as hell. Is there an acceptable(clever) way of installing a 12 volt switch that will retain the same appearance? | | |
