2 members (Hotrod Lincoln, delky), 160 guests, and 6 robots.
Topics128,266
Posts1,058,385
Members48,485
Happy new year guys!
This should be a simple one. What can I use to drop 12v down to 6v for the heater motor in my '54 Bel-Air? Runtz or a ceramic resistor from Rod&Custom supply?
thanks
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
What you need is part number 02415HR Reducer from Fifth Avenue It is a wire wound resistor that works better than the ceramic type and is in a cool looking finned aluminum housing. A runtz will work for the gas gauge in the dash and you should be set. Thanks Randy grin grin
Sounds good, how do I order? Do I send an email to Fifth Avenue from the Links page or what?
Chip
They are on the links page or call 785-632-3450 or e-mail them at <[email protected]> thanks Randy eek eek
