5 members (Hawkman, Peggy M, Otto Skorzeny, BC59, 1 invisible), 178 guests, and 3 robots.
Topics128,078
Posts1,056,057
Members48,433
Hello all
I've a 66 GMC Burbled with 3 on the tree. Started looking into sealing factory 3 speed with an automatic. Any one have any suggestions / recommendations or the best auto to put in? Thanks & happy new year to all.
Riding in the Passing Lane
the biggest problem putting in a modern auto. trans. is you have to remove the crossmember that the bell houseing sits on. A better choice is a later model 4 or 5 speed manual. If you are retaining the stock rear end, an o-drive trans is preferable manual or automatic to give you better highway cruiseing.
1972 Chevy c10 Cheyenne Super
Thanks for you thoughts. Thinking more of using an auto from about the same era. Wife loves the Burb but hates the manual.
How about a nice aluminum Power-glide?
Nothing wrong with these transmissions; cheap and plentiful I imagine.
They put them behind 6s and 8s alike back in the day.
Loads of after market parts, upgrades, and support.
Good idea. I really want to keep the original V6 as it's a real strong engine
and maybe replace the rear end with lower gear ratio for highway speeds ( 60 - 75 ). Didn't want to get into a lot of work with the swap if I could get away from it. Would I need to find a powerglide out of a truck or would a car t-mission work? I would think a truck auto might be hard to find?
The GMC has a different bellhousing bolt pattern from a Chevy. It may be the same as BOP. You may need an adaptor for late type transmissions. You will also need to modify the drive shaft, fabricate some sort of auto shifter, & install an oil cooler.
Fred
B Online: Content
Fred
GMC bellhousing is all by it's self.
BC
1960 C60 pasture art
