5 members (FAST55, MickeyP, mo2cyl, Gdads51, 66flea), 87 guests, and 1 robot.
Topics128,049
Posts1,055,652
#905761 12/24/2012 12:12 AM
I have a 49 3100 and the rear leaf spring shackle hangers are shot. Does anyone know if anyone is making a repop or where I can find replacements, either new or used. Any help would be appreciated.
The part riveted to the frame is shot? Is it just the bushing in the hanger that is shot? New shackles come with new bushing to press into the hanger. Even if the shackle bolt wore through the bushing and wore the hanger a bit, you can salvage it with JB Weld or similiar. Just need to keep that bushing from spinning in the hanger.
Thanks DavidF the hanger is pretty egg shaped I may needto make a sleeve for the new bushing and make the openining in the hanger round again. I was hoping to be able to grind off the rivets and replace the hanger but I guess it's not going to be that easy. Thanks again for the help.
I would attempt to press in a new bushing and see how tight it is. The bushings are steel, so should hold their shape even if the shackle bore is out of round. Then, force JB Weld into the gap from both ends and call it a day. If the bushing goes in by hand, then you have more of a problem.
