1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90570 01/26/2003 5:31 AM | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | I need to replace the existing tail and turn signal wires do to deterioration.What would be the right guage of wire to buy a spool of?
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | |
#90571 01/26/2003 6:21 AM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | 6V system min 16 ga better 14 ga | | |
#90572 01/26/2003 7:37 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I agree on the gauge, but would buy some rolls of different colors. It's tough trying to chase down a problem with all the wires one color. I had to figure out an old jeep that had been wired with all black wires, took me forever!
Fred 52 3600 69 C-10
#90573 01/26/2003 9:31 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The previous owners of my dad's 1930 Fjord AA rewired the entire truck with orange wire, then just twisted and taped the connections. Luckily, a proper restoration harness was very cheap, or I would still be cussing at that electrical system! | | |
#90574 01/27/2003 4:31 AM | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Thanks for the info.Ive managed to get the stop and tail lights working.Next is the blinkers.Ihave power to the flasher but nothing comeing out.I get no power comeing out of the flasher so im asuemeing it is bad.I do not have the blinkers hooked up but i dont think that should make a difference should it?
#90575 01/27/2003 11:59 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | The wiring on a vintage vehicle is very simple, you guys make it difficult  You can use one color wire,as there is many more terminal points than colors. just keep track of it.Go to the electrial section of your Homeless Depot, buy a book of stick on numers.Number every termination and record it in a directory. You can buy wire at the same place,stranded thhn/thwn building wire is oil and gas resistant and far superior to the usual pvc insulated wire found in reproduction wiring harnesses.14 guage is easy to work with,can handle 10-15 amps without a voltage drop , 10 guage to the amp meter and charging system.Go to Radio Shack to buy termination barrier strips, use the Euro style, stick in the stripped end of the wire and tighten down the screw.Buy good quality crimp on electrial terminations(Panduit, T&B), use a quality crimping tool , not those made in China junk tool that comes in the cheap terminal kit.Buy a good sharp dedicated wire stripper, the small ones with the 10-18 guage stripping holes will last for years .Wiring is nice, no grease ,not heavy, no expensive tools and mistakes are inexpensive. | | |
#90576 01/27/2003 2:26 PM | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | You need to have it hooked up to the bulbs. or something to draw current through the flasher. Make sure you have the right flasher for the number of bulbs. Two or four bulbs. I think it is the resistance of the bulbs that heats the flashers to make them flash. | | |
#90577 01/27/2003 11:43 PM | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Thanks for that info.I would have wondered why all the flashers id buy were bad.  When i started on this truck it had no motor and none of the engine ,tail light or turnsignal wires were conected.I curently have every thing working exceppt the turnsignals.If i remove the flasher and run a wire from the hot terminal to either side it should run curent through so i can find wich wires are directionals? Are the three prongs on a flasher one hot,one left and one right?
#90578 01/28/2003 3:34 AM | Joined: Oct 2001 Posts: 10 Member | | Member Joined: Oct 2001 Posts: 10 | I would add that it is a good idea to use tinned wire. This wire has a coating of tin over the copper. It really helps for corrosion protection, the wire only costs a little bit more. If you have trouble finding it you can order many sizes and colours from Digikey - digikey.com. Great people to deal with.
I have an Alpha Chart, Rough gauge sizes vs amperage, note this is when the insulation melts. 30 ga 2-3 amp 24 ga 6-8 amp 18 ga 15-18 amp 16 ga 19-25 amp 14 ga 27-33 amp 12 ga 36-45 amp The amperage difference depends on the insulation. These are single conductor in free air ratings, for a bundle of 2-5 derate x.8, 6-15 derate x.7. Hope this helps David | | |
