8 members (tclederman, Hotrod Lincoln, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny),
179
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90491 08/13/2003 2:59 AM | Joined: Dec 2001 Posts: 13 Member | | Member Joined: Dec 2001 Posts: 13 | does any one know what you have to change to make a thruck 12volt that is 6 thanks | | |
#90492 08/13/2003 3:11 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Hello ff, Yes, a lot of us know that a good place to start is to read the entry that is listed on this site's Tech Tips page: The Ole 12-Volt Conversion Study that article a little and think about what you need in your coversion. Then ask questions - there are no dumb questions. Most people here try not to give dumb answers (but some of us just can't help it when we do). Good luck, Tim | | |
#90493 08/13/2003 3:06 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Also, the moderator of this board, Randy from 5th Ave Auto Parts has a nice boodlet on the conversion. Price is around $10.
Fred 52 3600 69 C-10
#90494 08/13/2003 4:58 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Basically you will need a battery, an alternator and a resistor. It can be simpler or more complex depending on which alternator you get. Look over the tech article and look at this one as well. Pick the parts that make it easiest. one wire alternator
54 3100 with 235 62 flatbed dump C60 with 261
#90495 08/15/2003 1:10 AM | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | One thing almost all of the books will say you have to do is resist the wire to the starter. I have never done this on my 49 chevy, started i dont know how many thousands of times, and it works great.
The only thing is that it runs faster, making starting quicker.
Brian K
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
#90496 08/15/2003 1:17 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I thought you resisted the wire to the points so they don't burn? Never heard the starter.
#90497 08/16/2003 12:10 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I run my 6V starter on 12 volts with 4/0 cables and is spins so fast it sounds like an electric drill, but it works great no problem. I just don't let it run long enough to get hot.
