1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#904143 12/17/2012 9:05 AM
So im in the process of running a new wiring harness in my truck. Its an 18 circuit from Hotrod Wiring.
Anyway it doesnt have a wire for the dome light. I have the original 6v wire still running above the driver door to the light but would like to replace it.
What gauge of wire should i use to do this?
Chooglin
1954 3600
[/url] www.tors54.tumblr.com
Chooglin #904161 12/17/2012 10:07 AM
This 1950 diagram shows 16g. Should be the same for your '54. The color of the wire may be different.
http://chevy.oldcarmanualproject.com/electrical/wiring/pdf/50truck.pdf
- Lonnie
My '54 3104
LonnieC #904191 12/17/2012 12:12 PM
Just what i needed. Thanks Lonnie
1954 3600
Chooglin #908798 01/05/2013 3:03 AM
On the 1956 12v system it shows 20 ga going to and from the dome. The 6v system needs more amps so the wire gauge will be smaller (larger wire). Its always safe to use smaller gauge wire (larger wire).
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
