| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 36 New Guy | | New Guy Joined: Jun 2012 Posts: 36 | hello everyone i am goin to flush my cooling system and i was just wondering if its safe to use finish liquid dish detergent or tide laundry detergent(powder) to flush my system and how much should i put in? i have a 51 chevy 3100 with a 216.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I don't think dish or laundry detergents would clean the system of the things that cause problems. You won’t find dirt or greasy grime in the cooling system unless you had a head gasket leaking or have been running around without a cap on you radiator.. The commercial cooling system flush that you can pick up at your FLAPS or farm supply contains chemicals that dissolve the rust and mineral deposits that accumulate in the cooling system. They are quite inexpensive and cornsidering that you only need to flush the system every few years you’ll probably spend more for lunch than you will for the flush. Also inexpensive is to refill it with distilled water and antifreeze to minimize the mineral build up in the future. Denny Graham Somewhere north of Sandwich, IL
Denny G Sandwich, IL
