9 members (Bill Hanlon, Otto Skorzeny, 50Chevy3100, cmayna, UnclePaddy, Tronman, TUTS 59, 2 invisible), 104 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#90270 11/07/2002 3:31 AM
I am in progress of rewirering my Chevy 1952 1ton truck.
The old harness was mostly non excisting.
I got all my wirering done and found that the diagram
in the 1948-1951 does not show any signal light wireing.
Was this an option or just an oversight in the diagram.
Any body has a diagram wich shows the signal light set up.
Also in my book on the diagram it shows a < ignition switch light.
Question where is this light located on the dash. If it is the one in the middle of the spido, than where is the high beam/ low beam light located.
I am switching fron 6 Volt to 12 Volt and making my own harness.
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
#90271 11/07/2002 3:54 AM
Originally these trucks came with only a left side tail light. I believe it was a dealer option to add a right side light and directionals..
Be sure you know whether you are using a 4 or 7 wire directional switch, it will make a difference as to how many wires you run to the rear tail lights..Also it will affect the number and types of bulbs you use for tail lights..When you are making the harness you will need to wire the brake lights differently depending on whether you use the 4 or 7 wire switch..
The ignition switch fits in a housing behind the dash. In the housing there is a hole for a push in lamp ( same as the gauge lamps ) that fits in that switch housing to illuminate the key switch are when the headlamp switch is in the park or head light position. This is not the same as the high low beam indicator..That is behind the speedometer..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#90272 11/07/2002 2:24 PM
You can find a schematic for turn signal wiring at YnZ Yesterday\'s Parts - Turn Signal Option .
