| | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | My stock 38 seat is not comfortable to drive any distance. There is only an adjustment at the bottom of seat back - the top of seat back is not adjustable. Been thinking about making a spacer to go at the top and move it out an inch or so. It would be pretty simple - has anyone else with stock seats had any problems? | | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | Yes for comfort. I have long legs so I put spacers out of tube steel and longer bolts under the mounting point of the seat. A taller spacer under rear mounts would tip the seat back forward but also the angle of the bottom would change too. | | |
