4 members (Bill Hanlon, Gray_Ghost, Otto Skorzeny, Robert Crandall), 160 guests, and 2 robots.
Topics128,162
Posts1,056,945
Members48,458
#902148 12/08/2012 4:43 PM
Can anyone tell me what this tube is that I assume someone added to this W-1 carb. Small tube runs to the bottom of the fuel bowl.
W1 carb
If you never tell a lie, you never need to remember what you said.
you know,
I bet that is the gas feed to aftermarket Southwind gas fired cab heater that Mr. Lang was describing recently.
Southwind heater info
Don't throw it away. this guy rebuilds them and would probably buy it from you.
Kurt
Kurt is right, that is the jet assembly for a Southwind heater. I have the very same item on my rochester B, to feed my heater.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
I should be able to just remove the feed tube and JB Weld that hole shut. Right?
Yes, absolutely.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Carburetion specialist
JB Weld will eventually fail in some gasolines. I have tested it here in the shop. Better to either fill the hole with a "rivet plug" like the others Carter used; or, if you don't have access to a rivet plug, remove the bowl cover, tap the hole with a standard machine thread, and insert a screw with a fiber washer.
As to the Southwind heaters, Bill Cannon did some really good articles on them many years ago when he was the editor of "Skinned Knuckles" magazine.
At one time, I cleaned out an old auto parts distributor that was a distributor for Southwind, and acquired two really nice metal cabinets chock full of N.O.S. Southwind stuff. Since I had no intent to start another career, I sent it all to Bill.
All of the school buses I remember as a kid in the 1950's and early 1960's were equiped with Southwind heaters. They really seemed to work very well.
Jon.
The Carburetor Shop
