10 members (DadsFirstPickup, TUTS 59, JW51, GRNHydra, Ponchogl, GradyB, Leo, Jon G, walterhvogel, 1 invisible), 50 guests, and 0 robots.
Topics128,080
Posts1,055,944
Members48,430
#901694 12/06/2012 5:26 PM
I haven't had a chance to tear into the transmission yet to give it a good inspection because I'm in the middle of the engine right now. I'm trying to focus on one area of the truck at a time but occasionally I stumble onto some opportunities to pick up spare parts.
Are there any known "weak" spots in this transmission where certain parts are prone to a lot of wear? I'm thinking like the shift forks, rear bearing support, idler shafts, etc. or was it a pretty good unit and "usually" only needs a good cleaning and a new set of gaskets/seals? I know a lot of it depends on the maintenance it received (or more so, lack of maintenance and gear lube) so I'm just looking for some insight on some of the items that are almost always in bad shape.
Shawn
Shawn
1950 3600 Pickup, 1958 Plymouth Belvedere
Cluster gear and low-rev slider seem to go first.
The rear support bushing and front U' joint that runs in it are also prone to wear.
My Blog
HI, Shawn, the synchro rings for 2nd and third wear out over time causing the transmission to jump out of third, and if it has been jumping out of gear it will need a shift fork to. It is a good idea to replace all the bearings when you have the transmission apart.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
Thanks guys. I appreciate the information.
Shawn
Shawn
