| | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | Looking for info. on converting barn doors to upper lift lid and barn doors on the bottom? Nice to get started on the right foot. cheers | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well, considering GM didn't produce anything like that it'd definitely be a DIY project - you'd start by finding a used lift gate and it's associated hardware, then you'd need to cut down the barn doors to fit [including a way to seal between top and bottom], and then you'd need to add additional hinges as the lower sections wouldn't work too well with one hinge each .... let us know what you work out  Bill | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Been done before Lot's of information about this in the archives. I posted this one quite awhile ago. | | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | Great, thanks for the help. I have all the hardware and think this is the way to go. cheers | | |
