2 members (Hotrod Lincoln, Jimmie D), 55 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
Z
Z Offline
I am looking a new 65-67 Mustang gas tank to put under the bed, what sending unit could I use so that my stock guage still worked correctly? Anybody done this?
If you need a tool and don't buy it, you will find you have paid for it and don't have it.
All depends on the resistance of the sender unit. I think later model GM sender units used a 0-30 ohm sender unit. Mismatched sender/gauge units will give you a valid empty tank reading (0 ohms) but full may be a different story. You could probably live with a gauge that reads 3/4 full when the tank is actually full.
I agree the gauge and sender need to be matched. Early Chevy 0-30 ohms to 64, late chevy 65 and up 0-90 ohms. But early **** is 73-10 ohms.
http://www.yogisinc.com/results.cfm/-/Category=376/product.htm
This is an electrical question so I'm transferring it over to the electrical bay.
Paint & Body Shop moderator
