| | | Forums66 Topics128,214 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90066 03/25/2004 8:46 PM | Joined: Nov 2002 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2002 Posts: 48 | I am looking a new 65-67 Mustang gas tank to put under the bed, what sending unit could I use so that my stock guage still worked correctly? Anybody done this?
If you need a tool and don't buy it, you will find you have paid for it and don't have it.
#90067 03/26/2004 2:50 AM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | All depends on the resistance of the sender unit. I think later model GM sender units used a 0-30 ohm sender unit. Mismatched sender/gauge units will give you a valid empty tank reading (0 ohms) but full may be a different story. You could probably live with a gauge that reads 3/4 full when the tank is actually full. | | |
#90069 03/26/2004 8:04 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | This is an electrical question so I'm transferring it over to the electrical bay.
