| | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 107 Shop Shark | | Shop Shark Joined: May 2009 Posts: 107 | All, I am having trouble getting the master cylinder nut off to bleed the brakes of my 52 pickup. I do not have a socket that size. Any thoughts? Is there a specific socket size? or tool made for this? Thanks in advance for the help!
Take care, Steven No one can drive us crazy unless we give them the keys.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Put a Crescent wrench on it vertically and turn it with Vise-Grips. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | You could buy a socket that size. Use a set of calipers and measure the nut, that would be the size. Just an idea. | | | | | Joined: May 2009 Posts: 107 Shop Shark | | Shop Shark Joined: May 2009 Posts: 107 | Thanks all for your replies. The master cylinder was removed because the nut was rounded off. It will need a repair kit as it is leaking as well.....I still love my truck. Later
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | Ah, I see someone tried the cresent wrench trick already.
