2 members (Hush, Otto Skorzeny),
122
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | i have a 55 1st. series 3600 with a four speed transmission,(i dont use the first gear) that i can get up to 55 mph but the engine is screaming.i have the truck for light lumber yard pick-ups and do not plan on towing. the numbers on the rear are NG1007 (on top) and 8699535 (on the drivers side).can anyone tell me what gear ratio i have and what gear ratio i would want? i do not intend to go faster than 60 mph. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | NG = 3600 rear-end/axle made in Detroit, 4.57 ratio
with 15" standard wheel/tires, your RPM at 60 MPH would be about 3,300
| | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | thank you tim. any sugestions on what ratio would be best for me. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Wait to see what someone with experience posts. I think people have posted information about hard-to-find 4.10 ratio rear gears. Other options would require changing out the entire rear end. Have you done work like that in the past?
| | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | no i haven't done anything like that but i know this site is the place for all the answers. i'm in no rush to do it but i saw an ad in the swap meet section for a rear(the ad was for an 8 bolt, i would need a 10) i think it was from a 65. i also read about it in the tech tips. | | |
