5 members (ShopRag, Phak1, Bill Hanlon, Otto Skorzeny, 3B), 116 guests, and 4 robots.
Topics128,034
Posts1,055,547
Members48,425
#900227 11/30/2012 8:50 AM
i have a 55 1st. series 3600 with a four speed transmission,(i dont use the first gear) that i can get up to 55 mph but the engine is screaming.i have the truck for light lumber yard pick-ups and do not plan on towing. the numbers on the rear are NG1007 (on top) and 8699535 (on the drivers side).can anyone tell me what gear ratio i have and what gear ratio i would want? i do not intend to go faster than 60 mph.
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
66flea #900239 11/30/2012 9:58 AM
NG = 3600 rear-end/axle made in Detroit, 4.57 ratio
with 15" standard wheel/tires, your RPM at 60 MPH would be about 3,300
66flea #900364 11/30/2012 10:18 PM
thank you tim. any sugestions on what ratio would be best for me.
66flea #900366 11/30/2012 10:32 PM
Wait to see what someone with experience posts. I think people have posted information about hard-to-find 4.10 ratio rear gears. Other options would require changing out the entire rear end. Have you done work like that in the past?
no i haven't done anything like that but i know this site is the place for all the answers. i'm in no rush to do it but i saw an ad in the swap meet section for a rear(the ad was for an 8 bolt, i would need a 10) i think it was from a 65. i also read about it in the tech tips.
