4 members (BC59, Gdads51, carbking, papas52), 89 guests, and 3 robots.
Topics128,181
Posts1,057,180
Members48,465
OK you guys have been so helpful in the past with all my questions, Here's one more, Does anybody know where I can get the inner axle seals for my 36 1.5 ton? They seal the axle next to the ring and pinion,They are held in by clips so when you slid in the axles you don't push them into the ring and pinion.Any help would be great! Thank you again.Dan
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
If they turn out to be difficult or impossible to find consider that with good wheel seals the inner seals may not be necessary. New axles don't have inner seals, just wheel/hub seals and the gear oil lubes the wheel bearings.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
That's the best News I have heard today Grigg! I did know that all the new trucks older than this one don't have them either,so why try and find them. The seals in my truck were all beat up from people shoving the axles in and the spring in the seals where in the bottom of the banjo housing,so they didn't do there job anyway, Thanks for the info....Dan
