0 members (),
151
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Does anyone know where to buy the countershaft roller bearings for a 1940 4 speed transmission? | | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | I took mine to a machine shop.. and got them in a few days
I like fixing stuff.
| | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | After a bit of searching, found these cross references
Chevy 142260 John Deere JD7538 and AA6619R Rollway 1206B Bower M1206EL Hyatt ORB1206
Chevy 121856 John Deere JD7502 Rollway 1207B Bower M1207EL Hyatt ORB1207
| | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | If you can take the old bearings to a bearing supply house they will be able to provide replacements by measuring the old ones or by cross reference from the numbers on the old ones. I live in city that is more administrative than industrial but this worked for me a couple of years ago (on a 1942 production 4 speed Chev transmission). | | |
