3 members (2-Ton, carbking, Guitplayer), 291 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
#898948 11/24/2012 1:10 PM
DOes anyone have the torque specs for a 55.2 235 engine? I need the connecting rod bolts, main caps, head bolts with tightening pattern, and balancer spec (if there is one?) Brian
1952 GMC model 473 dump truck
1951 Chevy 1500 stepside
All that info is in the oldcarmanualproject if you look...
Give me ambiguity
or give me something else
rod bolts 3/8 42-45lbs. 1/2 bolt size mains 95-100lbs. 1/2 bolt size heads 95-100 lbs, torque from the center out.
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag,
Thanks a million for the link. I have been looking for that for a while. This will save a lot of redundant questions on my part.
Baldpenny, thank you for looking up the numbers for me, I appreciate that. Brian
