2 members (rick46ia, NJC),
112
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Hey guys, My 1942 1.5 needs lower fender work where it meets the running board. Does anyone make a repair panel?, I looked and all they have is complete fiberglass fenders $$$. Problem is i don't know how much material rotted away from stock to keep the fender sitting right/square? | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Don't know if any patch panel is made for there but if you have a little skill you could fab a piece for there. I like puttzing around so I made my own. Pictures start here. Don't know if this helps. Have fun and good luck Dan | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Thanks Dan. I do have the skills and the welder. Problem is where the bolting flange meets the fender is rotted 1 1/2-2" up,so it will be all quess work as to make it look right. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | What's the other side look like? Gone too?
| | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Yes it's the same as the drivers side. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Hark! Tis that the season of projected lines and tracings on cardboard I hear??
| | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | I just figured a patch panel was available before the entire fender was. | | |
