0 members (), 40 guests, and 2 robots.
Topics128,072
Posts1,055,906
Members48,429
#89803 09/11/2002 3:39 PM
Junior Member
Junior Member
Well.. you fix one thing and more break wink My points went out so I replaced cap / rotor / plugs / and points... but now I know why they went out. My coil is leaking and seems to have a crack in it. I measured the voltage going to it and it's arround 12+ volts. I search the forum and found out I need an IC64 (12 volt conversion by PO) that has an internal resistor. My question is this:
Where is that external ballast resistor and what does it look like? I want to make sure that I remove it.
In my Camaros they run from the voltage regulator.
Thanks for any help!
Ohayden
53 Chevy Coupe (Daily Driver)
67 Chevy Camaro (Toy)
68 Chevy Camaro (Weekend Driver)
#89804 09/11/2002 4:51 PM
If your truck was converted from 6 V to 12 V, there is no ballast resistor because it was not used in the 6V system. If you use a coil on 12 V that is made to run with a resistor and you don't use one, sometimes the oil will boil out of it and sometimes the spark will breakdown the plastic.
1951 1 Ton Completed
#89805 09/11/2002 5:32 PM
Junior Member
Junior Member
Thanks truckernix... makes sense now. That's why I couldn't find the ballast resistor and that's why the coil killed my points and then itself. Well, I'll make sure that the new coil has an internal resistor.
Thanks again!!
Ohayden
#89806 09/17/2002 8:25 AM
:)howziit guys!
most ballast resistors i had seen were mounted on the firewall...close to the coil. they look like a ceramic insulator, shaped something like a miniature cinder block.
if you follow the coil's 12v wire, it will lead you directly to it.
certainly not trying to pull your chain...just trying to help. grin grin grin
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#89807 09/17/2002 8:05 PM
Hello, pardon me for jumpin' in here. Me and my son is getting ready to rewire his '45 to a 12 volt system (from scratch). We already put in a 12 volt coil and 12 volt battery. No need for the ballast? john.
