1 members (Donf), 102 guests, and 3 robots.
Topics128,026
Posts1,055,405
Members48,422
#897812 11/19/2012 10:40 AM
I have a 1965 Chevy step-side. The side inner fenders each have a metal 'L' shaped strip to hold the wood flooring into place that are welded/rusted to the fenders. Mine are too rotted to salvage. Which leaves me with 3 questions. 1. Do I just grind them off? 2. Does anyone make replacements? 3. If not, any tips on fabricating new ones? Thanks! Janine
new ones are available at Mar-K in OKC, OK.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
On the stepside beds, the edge angles are spot-welded at the factory, so they will have to be drilled or the spot-welds compromised, so they give up their hold.
All of the usual suspects, including LMC Truck, Classic Trucks, Jim Carter Classic Truck Parts and Mar-k, carries these stepside corner angles.
For the cost of the manufactured units, shop fabricating a pair, may not be the prudent approach. I believe they run approximately $30.00 per pair for the shortbed stepside edge angles, plus tax & shipping, from LMC Truck.
Thanks both of you for the quick replies. I checked my LMC catalog and found them...I had looked before I posted, but they weren't where I thought they'd be and missed the page they were on. (DOH!) If the weather holds like this tomorrow I plan on gettin-r-done. Janine
Janine,
I sent you a PM.
The neat thing about buying from Mar-k is they make most of the parts they sell, and they make them in Oklahoma City.
They are also running a 10% off sale this month.
https://www.stovebolt.com/ubbthread...p;Words=mar-k&Search=true#Post896901
