7 members (Gray_Ghost, cmayna, Rusty Rod, TUTS 59, Rusty Heaps, 49choptop, treegrower),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,067 Posts1,055,877 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 3 New Guy | | New Guy Joined: Oct 2012 Posts: 3 | Everyone is telling me to change out my 216 for 235. I have a 49 chevy 3600 3/4 ton truck. It was originally a farm vehicle. very little miles on it, been sitting for over 40 years. Has a small crack in the block and I know someone that welds cast iron. I was wanting to weld it up and use it. Everyone else says change it out. This is not going to be a regular driver and I like the idea of staying true to the history of the vehicle. Will you all weigh in on your thoughts? thanks | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Interesting.. I have a 1950 3600 that came from a farm in Illinois. My 216 ran, but had a few problems. After weighing the alternitives, I choose to replace it with a 235 (58-62 block) Pretty easy swap and I'm glad I did it. I still have the orginal 216 and will keep it. While mine is not a daily driver, I do drive it frequently. Going from 92 HP to over 145 HP helps where I live also. I kept the 'original' look to it.
I also believe the VIN number of your truck is on the engine. Anyway, something to think about.
Good luck and keep us posted..
PS, there should be some pics of mine if you click under my sig..
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "This is not going to be a regular driver and I like the idea of staying true to the history of the vehicle."
Try to fix the engine, and drive it, and enjoy it.
If you want to change the engine later, at least you can then save/store this one, knowing it runs.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I tell my customers to build it to make them happy not others. If you put a 235 in half the people will say cool and half will say you ruined it. Who do you want to please.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I am very happy with the 235 I have in my '51 burb, but if I had it all to do over again, I would have kept the 216. The most common and first question I get is "does it still have the original engine?"
Kurt | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | The most common and first question I get is "does it still have the original engine?" me too! and i lie through my teeth  and say "yes" i found through time the majority of the people asking me dont know what they're looking at anyway. the ones that do say "nice upgrade"  i look at it this way why have a ham sandwich when you can have steak for the same price. to ruin i,t which i would agree is to put a 350 or something else in that didnt directly bolt in. each to thier own as long as you enjoy it. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mike, When I asked you if you still have the original flat-head six, you immediately said "yes". | | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | Probable advantages for each:
Keeping the 216 -
The truck will be worth more money if you (or your estate) sells it. The truck will appeal to a larger universe of buyers if above The truck may be showed in even national shows as original The cost will probably be less than installing a 235
Installing a 235 -
The truck will have a few extra ponies. The 235 may be somewhat more reliable.
And remember, if you install a 235, the people that like the non-original swap will ask you why you didn't install a 261.
Make yourself happy.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | I know someone that welds cast iron. I was wanting to weld it up and use it. Even if the crack is external, you'll need to strip the block down to bare bones to get a good weld. It will need to be pre-heated, peened, and post-heated, then buried in sand to do a very slow cool-down. Do a complete overhaul while the engine is apart, and drive it for another 50-something years! If you don't want to go to the trouble of welding, there's a process called "stitching" where a series of overlapping threaded plugs are used to patch a crack. Jerry
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Nuthin' wrong with a 216 !! With the gearing you will have , a 235 will be only a small advantage in power. Build it so YOU are happy , not yer neighbour , he's unlikely to buy it when you are ready to sell. The 216 in my '40 has been cracked for 20+ years , still a daily driver !  | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I went with rebuilding the 216. Mine's not the original 216 but I don't tell people that when asked. If/when it dies, I'm either calling Jerry (Hotrod Lincoln) for a 235 or digging up a 261 depending at that point on what direction I've gone with the rest of the truck. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I went with a 235 from a 54 car. It is a better engine and really benefits from an M4F cam. With a 4.10 gear swap I was driving the freeway to work every day and was keeping up with the traffic. But it's not for everyone. Rebuild your 216 and have the rods machined for insert bearings. It's a change that can't be seen and keeps you from have to adjust the rod bearings. Also have the hardened exhaust valve seats installed, eliminating any issues with running unleaded gas. Most of all, enjoy the ride.
Fred 52 3600 69 C-10
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Do yourself a favor and look into the hardened seat issue, you'll find its not needed for most applications. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My machine shop talked me out of hardened seats...said definately not necessary. My 216 is in my garage ready to be reassembled. I choose to retain the babitted rods as there were shims still under the caps. I think it will go a long while before causing any issues. I did change to alumium pistons which will help reduce load on the rod journals and help them last longer...I guess. | | |
