Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (MNSmith, dt235sd, J Lucas, Hotrod Lincoln), 199 guests, and 6 robots.
Topics128,288
Posts1,058,579
Members48,492
How do I remove the light switch on 59 apache truck?
Jerry Rogers
there is a small button on the top of the switch (under the dash) that releases the pull-knob/shaft assembly from the switch body. Then unscrew the slotted nut (that the shaft passed through) from the front to release the switch. its easier than i described here!
i just gotta say, this question is probably the most asked question in stovebolt history.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
And makes you feel dumb when you figure out how easy it is to release!
I never have figured it out. The button is easy to find and push, but there is always some trial-and-error for me to figure out which way to turn the handle and pull it out. Happily I don't do it often enough to get good at it.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
Yeah, I remember I broke the dang thing trying for the first time.
V
V Offline
Question : How long do the OEM ones last? Just a range would be fine, 1 day - 60 years? I'm certain it varies , I don't have a clue.I have replaced one and have a spare.Just asking from knowledgeable people who know trucks.Thanks.
'57 3200
peddler - I've had a lot of TF series trucks with functional original switches, very few bad - no reason they can't last "indefinitely"
