6 members (KEVINSKI, Gdads51, UtahYork, Sjm, Hotrod Lincoln, Goach2), 97 guests, and 3 robots.
Topics128,264
Posts1,058,352
Members48,485
#896566 11/13/2012 9:54 PM
Found another '54 3100 but the frame has a huge crack which has been repaired at some point in the past. I have located a couple of frames in the area, one is a 53(with the cab still attached) the other is 54 with no engine or body work. Besides taking a tape measure with me, is there anyway to identify what year a frame is? Or what will fit the 54?
Thanks for the help.
....David
A 54 frame will have angle bellhousing mounts and the frame does not have much of a hump over the rear axle.
My Blog
