4 members (Gdads51, Hanks custodian, rfs56trk, tclederman), 94 guests, and 2 robots.
Topics128,132
Posts1,056,376
Members48,441
What is the secret of removing the lock from the glove box door on my '37 truck?
I have the door out, but can't get the nut on the lock mechanism past the lock post. Is there some release for the lock post that I am missing? I'd appreciate any help given.
CAB
I think I recall the key is used to retract the lock post. It was a long time ago since I had that task. If I'm faulty in recollection, I'm sure someone will offer a correction. I didn't have they key for mine and the locksmith that up until then had been able to help with the other locks didn't have the "magic key" on his large key ring.
I'm not sure if it's the same, but i had to undo the post on the back.
I used a set of pliers and unscrewed the post on the back and the lock just came out.
My truck is a 40.
There is a trick to doing it. I will get out my spare and refresh my memory on removing the latch. Will post it tomorrow.
1936 GMC T-14 1/2-Ton Pickup
Got this from a VCCA member.
Pull the square outward from the back of the lock, jiggle the key and the key comes out as does the latch and latch.
To reassenble, push the latch in until it clicks, look into the lock cavity and push the latch just enough to see the indention in it, push the cylinder in (with the key in it) and the peg on the back of the cylinder lined up with the indention on the latch, turn the key and it will click into place.
back yard wrench turner
And what if I don't have the key?
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
dunfire got his information from me.....so.....I can tell you that there are three possibilities. #1 - find a locksmith or Chevrolet enthusiast with a bunch of try keys and see if you can stumble across the right key. #2 - have a lock smith pick the lock and if he can get it open and maybe a key could be made. #3 - forget it because 1, 2 and 3 are the only choices you have.
Thanks Joe. Sure like your '37. smile
Wayne
1989 Silverado
it has to be turned counter-clockwise. It goes about 1/8 of a turn beyond open while, at the same time, pulling back on the bottom of the latching bar that sits on the rear of the assembly. Then everything just comes apart.
