4 members (MickeyP, TexasA&M48Truck, walter74, cmayna), 42 guests, and 4 robots.
Topics128,012
Posts1,055,321
Members48,419
#895921 11/11/2012 8:26 AM
I purchased a timing light from HF
...link...
It's been working well
If you own this light I have a question for you
There is an advance dial in the back
...pic...
...pic...
What I need to know is that when the dial is turned all the way left where does it indicate on the indicator. Is it 0
As you can see form my pic the little decal on the back as come loose so I don't know where 0 is. I'm pretty sure all the way left is 0 but just want to make sure.
This will save me a 40 mile trip to the store to look at one on the shelf.
Does this image help?
web image
Thanks for the pic.
I cannot really make out where the indicator on the dial is
or if its set a 0 in that pic.
thanks for the link
One thing you could try is this.
Just borrow a friend's timing light and check the degrees BTDC with his light. (For instance, his light might show timing is at 5 degrees BTDC.) Then, shoot your timing light and adjust the knob until the timing mark shows dead on for zero. Then temporarily put your sticker back in place with the 5 degree mark at the indicator on the knob. You can then re-check yours by setting the indicator to zero and see if the timing reading is the same.
thumbs_up
Thanks again
Moderated by  MNSmith
