1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#89593 12/28/2001 4:09 PM
What's the differance between and a generator and an alternator? How can I tell what I have?
57 3100 235 3 spd
A generator will be a black cased with a large pulley on the end and is what would have came on your truck from the factory if it was built before 1963. By contrast an alternator will be in an aluminum housing, will be much shorter in length and much larger in diameter as compared to a generator.
The advantage of an alternator is that it is able to charge (produce current) at idle and low rpms whereas a generator is not. That allows you to have brighter headlights and easier starting. In addition most alternators have a built-in solid state regulator which makes the charging system much more reliable.
It is common practice to replace a generator with an alternator to gain the reliablity of a modern charging system. Thanks Randy grin grin grin
Thanks for clearing that up.
Acme
57 3100 235 3 spd
A gen will charge a flat dead batt where an alt will not. grin
Philip Bland
1961 Chevy Apache C-10 Shortbed Stepside
235 ci
1964 Chevy C-10 Custom Shortbed Fleetside 350ci
Bedford,Ky
Yup, as Neil Young sings " I don't like to go to the flats cause I can't park up on a hill"
