1 members (Bill Hanlon), 48 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#89586 08/27/2004 3:32 AM
Junior Member
Junior Member
' Offline
Can you take a heater out of a 12 volt system and put it in a 6 volt system and it work?? I have a heater out of a '60 C-10 and need one in a '50 Chevy 4400. :confused:
#89587 08/27/2004 5:52 AM
Probably no, unless you also convert the truck to 12 volts.
If you run a 6-volt motor on 12 volts it turns too fast, and may not last as long as it would on 6 because the mechanical parts are subjected to more stress.
If you run a 12-volt motor on 6 volts, it may not turn at all, but if it does it will be slow and will be drawing more current than it was designed for and likely will fail quickly because the electrical parts are pushed beyond design limits.
Its possible to rewind a motor to use a different voltage, but those motors are relatively cheap, so buying a replacement motor might be the best bet.
#89588 08/27/2004 7:16 PM
My '55 GMC has a Radio Shack converter in it for 6V to 12V, 3 amps max. Does anyone know how many amps a heater fan motor draws?
#89589 08/27/2004 10:26 PM
Riding in the Passing Lane
You could adapt it but you would have to install
a 6 volt motor. It will draw about 7-10 amps.
Those converters are only good for solid state
radio,s or gauges.
1972 Chevy c10 Cheyenne Super
