| | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | I have a '59 panel. There is a large void between the body panel and the inner wall that runs the length of the bed. This area is coated with rust. What are my options for dealing with this rust?
thanks
Is rust considered a body style?
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | if you have no rust through i would put por 15 in there [ use a good resperator if you spray it] | | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | Thanks, Leonard. I figured it would take some type of spraying. But how do you spray inside a space that is 8' x 3' x 3" with limited access points?
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Depends if it is California surface rust or back east rot rust. Surface rust: Can't see it from the drivers seat. Rot rust: Power wash or sandblast and then bedliner spray or undercoat. But don't blast thru it. I never would feel good about just Por 15 right on old virgin rot rust. Maybe that's OK though.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Eastwood sells rust-proofing stuff in a can with a long hose to spray inside enclosed areas, or through a hole. Could be convenient here.
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There are three access covers on either side, on the inside of the panel truck, which provide access to the area you are speaking of if you can't reach from underneath.
