5 members (NorCal52Suburban, Hush, Cosmo, LAROKE, 1 invisible), 62 guests, and 2 robots.
Topics128,073
Posts1,055,908
Members48,429
OK, I have stuck a paper clip in the little hole & turned the key in every posistion I can think of, how do ya get the key cylinder out?? This is on my 66 C-10, I am using the key out of my Chevy II to turn the cylinder but I can't get it out. I have done it in the past with a new switch & tumbler off the shelf but that was with new parts. I have a new cylinger & it has 2 holes in the face of it which is really interesting...any help out there?
Turn the key to the "on" position then push the pin with the paper clip. Pull the cylinder out while keeping pressure on the pin.
Does the paper clip only go in an 1/8" or so? Also my key won't stay in, it pulls out in any position so when I try to pull it out the key comes right out. Should I take the key out & try to hooK it with something or does it need to be in the cylinder?
Tnanks
Do what I did. Take it to a locksmith and let him do it. Paid $20 and he took out the old cylinder and installed a new one for me.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
Once the cylinder is in the "on" position I think it will still come out with the key removed using something to grab it with. Try it and see.
Riding in the Passing Lane
If your switch has an assesory position turn it to to that & insert the pin. Turn it a little farther & pull it out. You can use a hook tool or snap ring plyers. Put the new one in the same position & use the corresponding hole.
1972 Chevy c10 Cheyenne Super
You can only take it out if you have the Original key in it. If you have no key call the locksmith. Jo
Just performed this chore. Ypu've got to hold your mouth just right (kinda like fishing). Put the switch assembly in a vise. turn the key, insert a paper clip in the hold and you'll feel the spring retainer depress, use a very small screwdriver to pry the switch from the housing. Goes together easier.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
