7 members (baldeagle, Southerntruck, Hanks custodian, Woodcmiami, J Lucas, Rusty Shackleford, TooMany2count), 79 guests, and 1 robot.
Topics128,133
Posts1,056,398
Members48,441
#893832 11/01/2012 8:57 PM
I know it's only 10 years old but....
Engine dies at idle.
RPM drops to 2-300 and then it dies.
Turn switch on to start.....nothing.
Switch again started fine. Clock set back to 12:00
Battery checks good at Pep Boys.
Alternator putting out 12-14v
Truck runs fine above idle.
2003 GMC V8 Small block.
Suspect an electrical switch gone south, but where to look????
Any help would be appreciated.
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
Jon,
The first place to look is: REMOVE and closely inspect the side terminal battery connections-- especially if it has the type positive cables where they stack one on the other.
They have a habit of growing resistance causing corrosion between the two and many times it will not be visable externally.
Bob Taylor
I've had trucks do weird things just because the battery cable was loose. Check this first.
My 46 GMC on Photobucket
Make sure ground connections at the engine and body are clean too.
Thanks guys
Cleaned everything.
Still drops RPM and dies at idle, with foot off gas..
Runs/drives fine at or above 800-1,000 RPM if I keep my foot on gas.
Thanks again.
Jon S
Las Vegas NV
Is your clock still resetting? If so, you may have a serial bus problem where the wiring plugs into the back of the instrument cluster.
On some of the later models the instrument cluster can actually cause problems if it has problems in it or the connection to it.
You really need to take it to a shop with a good scanner to let them see what is going on.
I've had this problem, you need 2 things
1-toothbrush
2-throttle/intake cleaner(not carb)
You need to clean the throttle body.
The battery went dead, ECM can't find the proper throttle position,
You probably had symptoms like flickering lights, p/s cutting out, thought alt was bad. Do this and it will run like a top.
CEL might come on, you can clear with a cheap obd2 scanner, or it might go out on if own if you drive it til it meets criteria.
There is a YouTube video on this exact thing,
Type in clean throttle 5.3 L or something like that
