5 members (Tronman, Otto Skorzeny, TUTS 59, Millenimech, 1 invisible), 116 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#894391 11/04/2012 1:26 PM
I have a '59 panel. There is a large void between the body panel and the inner wall that runs the length of the bed. This area is coated with rust. What are my options for dealing with this rust?
thanks
Is rust considered a body style?
arturo7 #894426 11/04/2012 4:52 PM
if you have no rust through i would put por 15 in there [ use a good resperator if you spray it]
arturo7 #894447 11/04/2012 6:43 PM
Thanks, Leonard. I figured it would take some type of spraying. But how do you spray inside a space that is 8' x 3' x 3" with limited access points?
arturo7 #894551 11/05/2012 1:52 AM
Weed sprayer?
arturo7 #894770 11/05/2012 11:31 PM
Sir Searchalot
Sir Searchalot
Depends if it is California surface rust or back east rot rust. Surface rust: Can't see it from the drivers seat. Rot rust: Power wash or sandblast and then bedliner spray or undercoat. But don't blast thru it. I never would feel good about just Por 15 right on old virgin rot rust. Maybe that's OK though.
bartamos #895497 11/08/2012 9:56 PM
Eastwood sells rust-proofing stuff in a can with a long hose to spray inside enclosed areas, or through a hole. Could be convenient here.
'57 Chevy Suburban; '70 Chevy Impala.
arturo7 #895603 11/09/2012 12:20 PM
Sir Searchalot
Sir Searchalot
There are three access covers on either side, on the inside of the panel truck, which provide access to the area you are speaking of if you can't reach from underneath.
