2 members (Ponchogl, Shardean), 85 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
#893292 10/30/2012 3:28 PM
I'm looking for a bushing for the temp probe. edit( threads into where the probe attaches)
this is the part from classic parts.(I'd like to run out and get one today)
...reducer bushing...
anyone know what size the bushing is?
Id like to find one at the flaps.
its not 3/8 pipe or 1/4 pipe.
235 head temp probe, need to reduce to 1/8 pipe.
thanks
DADS50 #893299 10/30/2012 4:02 PM
Hole in head in 1/2 - 14 NPT
BC
1960 C60 pasture art
BC59 #893302 10/30/2012 4:08 PM
Gus -
> NAPA Part #BK 7011798 I had to file the center opening in the reducer to enlarge it a little to accept the bulb. Other 'Bolters say that their temp probe fit through the reducer with no problem. My temp gauge is a reproduction, possibly a little different size than the original.
Mine is in a Dec 22, 1959 "848" head on a '54 235, '54 reproduction temp gauge from the Truck Shop.
- Lonnie
My '54 3104
DADS50 #893303 10/30/2012 4:08 PM
The 3/8 to 1/8 adapter I have right now is to big
It's a 54 235
DADS50 #893305 10/30/2012 4:11 PM
I'll try napa.
Just threading an electric sender that is 1/8 pipe.
Didn't want to pay 8 dollars shipping for a 7 dollar part.
DADS50 #893308 10/30/2012 4:33 PM
Just so you know, the hole for the temp gauge is larger in an "848" head than in the original '54 head. The NAPA and Classic bushing are for the "848" hole.
The '29-'57 MPC noted that the "temp. gauge reducing bushing" was supplied with replacement 235 head casting #3836848 and with replacement 261 head. No GM part number for the bushing.
> Group 0.269 HEAD, Cylinder - Part #3730415, &3730416
- Lonnie
My '54 3104
DADS50 #893311 10/30/2012 4:36 PM
I don't have an 848 head. So will that napa part number not work?
DADS50 #893313 10/30/2012 4:41 PM
I don't believe so. I believe that the inside hole of the NAPA bushing is the same size as the hole in your '54 cylinder head. The bushing was to allow an earlier model temp gauge probe to be used in a later model head that has a larger hole for the probe.
Might ask another 'Bolter who has more experience than I do.
- Lonnie
My '54 3104
LonnieC #893315 10/30/2012 4:53 PM
- Lonnie
My '54 3104
DADS50 #893317 10/30/2012 4:58 PM
Ok
I'm just trying to adapt my original probe size to 1/8 pipe for an electric sender.
I thought the original size is 3/8 pipe but the 3/8 bushing I bought wont thread in.
...pic...
I'll take the works over to napa later see what I can find.
DADS50 #893336 10/30/2012 6:11 PM
3B Offline
Hy DADS50, you need a 1/4" NPT X 1/8" NPT bushing Weatherhead p/n 3220X4X2, hope that helps.
DADS50 #893342 10/30/2012 6:29 PM
Originally Posted by DADS50
Ok
...pic...
I've tried the 3/8 and 1/4 pipe
The 1/4 dropped in the hole
You can see in the pic. Is it pipe?
Struck out at napa.
DADS50 #893352 10/30/2012 7:07 PM
The thread on the mechanical temp probe is NOT pipe thread. I believe it is 1/2" x 20. I will confirm that.
My Blog
DADS50 #893355 10/30/2012 7:09 PM
Ok.
Thanks. I was going about it wrong.
Mine looks like a 5/8 diameter
DADS50 #893357 10/30/2012 7:11 PM
The thread is 5/8" x 18.
My Blog
DADS50 #893359 10/30/2012 7:14 PM
Thanks All
Sorry for the confusion
Napa and Orielly both told me it was pipe. I took the probe with me for comparison.
DADS50 #894298 11/04/2012 1:02 AM
Ended up having to make an adapter
...pic...
Ran a stock die nut on a 3/8npt x 1/8npt pipe adapter.
No leaks........yet
DADS50 #894301 11/04/2012 1:38 AM
Good job!
My Blog
