5 members (32Fordpuchoptop, Otto Skorzeny, Mike B, Bill Hanlon, bluechev), 48 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#8931 11/11/2003 10:58 PM
how do i set the rocker arms on a 1953 235 engine i have never done them before and i just rebuilt the engine if someone can help asap that would be great
#8932 11/12/2003 12:00 AM
If you have hydraulic lifters, you have to adjust while running - engine warm - 1 1/2 turns after lash is removed (for my model).
I just rebuild my 54-235 w/ hydraulic lifters. To get things going without much ado, I adjusted each valve cold, to the point where the push rod could be rotated by hand. I had a stuck lifter, and trying to adjust the 1 1/2 turn after lash caused my compression to go away on the cylinder with the stuck lifter.
This was good enough for initial running and breaking in the new cam and lifters.
Actually, when I first got my car 20 years ago, my mechanic adjusted for hydraulic lifters (i.e. a gap). After a couple of years, I reground the valves and figured out the correct way. After that, the car ran quieter, but the performance seemed about the same.
#8933 11/12/2003 12:28 AM
it has solid lifters i set them 13 on the intake and 20 on the exh
#8934 11/12/2003 8:05 PM
Ralphy, i just went thru this mess not long ago, you said check casting numbers on block what/ where can i get this info. mime is a 2nd 1955 235 truck
