9 members (48jim1ton, Gdads51, Forty9, Hotrod Lincoln, gswbbc, frogfarmer, Wayne67vert, sron48, dt235sd),
75
0
Mod | | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | Need to know what went into the holes on the dash,and in which position. All were empty. Three holes above radio and one hole left of instrument cluster, between cluster and headlamp switch. 58 Apache. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | ok, the first one to your left of the steering wheel is the light switch, second is your choke, then on the other side is your wiper, then a cigar lighter (or delete button) then throttle cable. below the wiper is radio knob (or delete button) the big oval hole is the radio hole, (you can leave that or get a radio delete plate for it as well) then another radio button/delete button under the throttle knob.if there are any more holes they are not factory. hope this answers your question, Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a picture of most of it Bill | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | Thank you for the info. Could not find anywhere on the net. ok, the first one to your left of the steering wheel is the light switch, second is your choke, then on the other side is your wiper, then a cigar lighter (or delete button) then throttle cable. below the wiper is radio knob (or delete button) the big oval hole is the radio hole, (you can leave that or get a radio delete plate for it as well) then another radio button/delete button under the throttle knob.if there are any more holes they are not factory. hope this answers your question, Indy  | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | Wow, mine is really messed up. Thanks for the picture.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
