11 members (TexasJim50, cmayna, Hotrod Lincoln, WICruiser, Chip O, KCMongo, Jaison, Donf, Woodcmiami, Bill Hanlon, MNSmith), 78 guests, and 2 robots.
Topics128,032
Posts1,055,523
Members48,425
#892814 10/28/2012 9:46 PM
Need to know what went into the holes on the dash,and in which position. All were empty. Three holes above radio and one hole left of instrument cluster, between cluster and headlamp switch. 58 Apache.
ok, the first one to your left of the steering wheel is the light switch, second is your choke, then on the other side is your wiper, then a cigar lighter (or delete button) then throttle cable. below the wiper is radio knob (or delete button) the big oval hole is the radio hole, (you can leave that or get a radio delete plate for it as well) then another radio button/delete button under the throttle knob.if there are any more holes they are not factory. hope this answers your question,
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
a picture of most of it
Materman #892838 10/28/2012 11:07 PM
Thank you for the info. Could not find anywhere on the net.
Indy wink
Flxible #892839 10/28/2012 11:09 PM
Thank you for the pic.
Wow, mine is really messed up. Thanks for the picture.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
Moderated by  ndkid275, Phak1
