6 members (Nick in Manitou, Phak1, Otto Skorzeny, Hush, MickeyP, 59 fleet), 66 guests, and 2 robots.
Topics128,188
Posts1,057,331
Members48,469
#89246 11/30/2004 5:10 PM
I decided to test my fuel gauge and sending unit before I put them back in and found that the gauge will only go up to 1/4 tank and stops but the needle is free to float when I move the gauge from left to right. Any ideas as to why it only goes up to 1/4?
#89247 11/30/2004 7:44 PM
sounds like the resistance is wrong, or the voltage is wrong. if you have specs on what those should be, and a multimeter, that would be the first thing to check.
-Mike R.
#89248 11/30/2004 11:41 PM
Is the gauge housing grounded? If not, and you've only got wires to and from the terminals, it will work like that. The gauge housing needs a ground wire attached if you're bench-testing it.
#89249 12/01/2004 12:15 AM
Nope, I'll try it again with a ground
#89250 12/01/2004 12:35 AM
That was it! Works great. Thanks
#89251 12/01/2004 1:27 AM
I love it when a plan comes together!
grin grin grin
