5 members (Opelika Tom, fonz8261, klhansen, TooMany2count, CandoBrent), 95 guests, and 2 robots.
Topics128,077
Posts1,056,281
Members48,441
#892410 10/27/2012 7:14 AM
I will be doing some body work on the front lower end of the cab and will be removing the left fender(drivers side). Do I have to remove the front grill before removing the fender?
No,You can remove the fenders without removing the grill.
Pete
I've had to do the same on the front right side , I'm at the stage where I've taken the outer and inner cowl panels off. I've been able to obtain new replacement panels now I have to just get started with alignment etc. I had to take the door off which helped for better access but someone else mentioned that I should put the door back on and see how the new panel lines up. It was a good idea as I found the new panel needes some adjustment and wouldn't have seen it with the door off. good luck
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
